is my engine ok?
![Unhappy](https://www.evolutionm.net/forums/images/icons/icon9.gif)
i was redlining 3rd and went to shift 4th but sumhow i caught second. the rpms shot to almost 9k and i instantly put the clutch back in...after it happend the car seems fine...did i just cause some major damage???
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
As long as its running fine you are ok. You should only be worried if your engine is obviously not running right and you hear noise from your head. Too high of RPM can cause valve float which will cause the valves to stick open longer than they should, and your pistons can slap the valves. You shound like you are fine though
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Originally Posted by diiirk
i was redlining 3rd and went to shift 4th but sumhow i caught second. the rpms shot to almost 9k and i instantly put the clutch back in...after it happend the car seems fine...did i just cause some major damage??? ![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
Just keep driving and listen for any new noises and keep your fingers crossed
