in car video (slow?)
Old Jan 12, 2006, 12:22 PM
DreamLike1's Avatar
Where in sactown
Old Jan 12, 2006, 12:51 PM
ThEyElLoWoNe's Avatar
sacramento, ca near marconi ave and watt
Old Jan 12, 2006, 01:04 PM
R3dline's Avatar
Get some cams! Im staying in Stockton for the moment. I can show you my ride how it runs with proper mods if your interested.
Old Jan 12, 2006, 01:08 PM
kmcconn9's Avatar
holy crap thats slow!! Get tuned and your problems will be solved..
Warrtalon's Avatar
Getting cams doesn't solve his current problem. The point is not to figure out what mods to install in order to go faster - the point is to find out why it's currently so much slower than it should be...
Old Jan 12, 2006, 01:36 PM
byron3636's Avatar
Think of it as 10hp for every 100lbs.
Three fat friends ~ 700lbs, (I weigh just under 200 so 900 total) got in my car and i almost stalled in first... they were like "you ok?" ... me: "yes, i'm just not used to you fat F's in my car."
Old Jan 12, 2006, 05:23 PM
fsugatorbait's Avatar
I actually nodded off waiting for you to get to 100.
Old Jan 12, 2006, 05:28 PM
KOEvo's Avatar
I think it's just me but... Did the 2 videos seemed the same to ya'll also?
Old Jan 12, 2006, 06:26 PM
well to some it may seem slower because you have a lot more mods than i do.... either way i think its slow so i guess this means its time to get it tuned and dynoed... thanks for the responses guys! anyone else have input??
Oh and thanks for the offer r3dline...if im going to be in the area i will get ahold of you!!
Old Jan 12, 2006, 06:34 PM
Vroompsh's Avatar
wow, maybe its cuz im not used to seeing a close-to-stock evo anymore, but thats not right...check for boost leaks?
Old Jan 12, 2006, 06:40 PM
I did like a week ago on all ic pipes, and it is still actin this way
Old Jan 12, 2006, 06:50 PM
sgtevo's Avatar
Check with your local tuner see if you can get a wide band hooked up to check your AFR then you may want to consider getting a flash try jestr at jestrtuning.com i have seen him tune evos with similar problems. Good luck man let us know what happens.
Old Jan 12, 2006, 08:05 PM
JuancaROD's Avatar
It sounds like you have a huge exhaust leak. Also I don't see your turbo kicking at ~3500 RPM, my EVO when was stock was way faster!
You should follow Warrtalon advise, instead of going for more mods get that problem solved.
Old Jan 12, 2006, 08:15 PM
Enyth's Avatar
yeah my evo is stock and mine seems faster. only if i had a video camera to record it
Old Jan 12, 2006, 10:16 PM
FinsNCanes's Avatar
What gear were you in...?
