intake problem...
intake problem...
i jes installed a k&n typhoon intake, the first time i installed i blew the hose off the stock bov the first time, then went back took everything off and put it all on again and made sure all the clamps were tight and checked everything, gave it gas and first gear, spiked at 20 psi as usual then at 6k rpm it felt like blew a hose off again and i threw a cel, it hit hard...i checked everything, and all is well, could someone please help me, my car is sitting out front thanks guys
ian
ian
Originally Posted by ScoobyBoy2
yeah i figured that one out, im looking for help....there is no logical reason why one intake would differ from another one...
I was about to help until I saw this. If you won't take our word for it, then you aren't worth our time. The Typhoon is the worst intake for the Evo. The End.
is this guy serious, the reason it makes no power and causes probelms is due to the design on the pipe and the way it causes the air to flow, i am not sure that my time posting is even worth it
thats touching, unlike u i use this forum to gain knowledge and for technical help, not to post *****...
You just came here with a totally jacked up car after installing the worst intake for the Evo. You refuse to believe that different intakes have different designs, you refuse to listen to our warnings, and then you curse out evolved members who are well known for providing great help. Just because my message comes with a firm hand, it doesn't make it less valuable. I'm not here to hold your hand like a kid, so suck it up and listen.
**** u, ur such a loser, i saw ur post towards everyone, ur dick there is no logical explanation to why one piece of aluminum pipe and a foam filter would differ from another one....
