Reverse Grind
Reverse Grind
more then half the time when i put it into reverse it grinds in, anyone know what it could be or has anyone had this problem? Could it be the syncro? TIA
Try this: Depress the clutch and hold it, shift into second, shift into reverse, then go. The syncro in second may be a bit easier. First gear's syncro gets enough wear or I would suggest that...
