Starter Problems?
Starter Problems?
The problem i am having is that my car wont start. I checked the battery and that isn't the problem, and a friend of mine heard it and right away said it was my starter. I have buschur stage III upgrades (without cams though) and i also added the walbaro fuel pump. I was wondering if anyone had been having troubles with their starter because i would just like to kind of know what is wrong with the car before i have it towed to a shop.
You checked the battery and said it was ok, I would check and see if you are getting enough power to the starter, if you are, it probably is the starter,
could always take the starter off too and bench test it, to double check, and replace it yourself, instead of taking it in. just remember to disconnect the battery.
