Driver Side Window Loose?
Old Jan 20, 2006 | 11:49 AM
fuzzychi's Avatar
Well I just noticed this today, while I was driving around 35-45mph, when I put the driver side window down I could see the window move back and forth. It is also making a bit of a rattling noise as I guess the glass is hitting up again the door or the mounts inside the door that hold the window. Has anyone else had this problem? Or is this just another one of those rattles that occur "naturally"?
Old Jan 20, 2006 | 12:14 PM
btuneallen's Avatar
Take it back to dealer and have them check it out.. the window maybe loose on one of the tracks.
Old Jan 20, 2006 | 12:22 PM
forbidden color's Avatar
If the window is down a bit, the wind causes that, but it shouldn't be lengthy movement.
Rattling noise maybe attributed to the ceiling, or A or B column cover or even the door cover since when the window is down there are some gaps between the outside door and inside door panel.
But I would take it back to the dealer or compare it with a friends evo first before dealers make worst case out of it.
good luck.
Old Jan 20, 2006 | 12:40 PM
GPTourer's Avatar
Yeah, mine flutters a little when the window is down - that part is normal. But it does not make any noise.
Old Jan 20, 2006 | 03:06 PM
althemean's Avatar
my passenger side does it....but I cant justify taking the car to a dealer
Old Jan 20, 2006 | 08:45 PM
denolloyd's Avatar
My drivers side does the same thing... No noise though...
