which gauges do you have for upgrade turbo?
For those that run bigger turbos which gauges are recommended? I have boost, egt and afr gauge at the moment. If running a bigger turbo which guage is most recommended...I do plan on getting 3 more gauges to go along with the 42 draft design panel. Its either no more gauges or if I get more it has to be 3 to fill out the panel.
Gauges help a little IMO, but a data logging device doesn't clog up your car, make you look like a ricer, and is much more helpful.
Something to think about, also, is your AFR gauge a wideband? If it's not, it's worthless IMO.
Originally Posted by 4TUN8
Doesn't that data log as well? IMO those other gauges....they aren't going to help you that much.
Originally Posted by IEXCELR8
No, I will be adding OP/FP gages. I have the uego with the AEM.
Do you have the AEM? If not what ems are you running?
You have Shearer kit!! Looks great BTW, did you install it yet?
