Awd?
Besides our superiour suspention setup "our suspention do not require an anti nose lift kit" I believe the WRX has a limited slip rear diff and we have a 1.5 way limited slip rear diff. Basically
ripped us off on the Front LSD
![Mitsubishi Logo](https://www.evolutionm.net/forums/images/smilies/mitsu_logo.gif)
![Rant](https://www.evolutionm.net/forums/images/smilies/complain.gif)
Originally posted by evoloverebdb
also, the evo is 50/50 split, but the wrx is like 70/30 towards front bias, which is as boring as it gets!! the sti will change that.
dave
dave
But your right about the STi, it gets a driver controlled center differential (DCCD) that works similar to the ACD in the Evo VII. It is adjusted manually by a rotary knob that allows the split to range from 35/65 to 65/35, or it can run in automatic mode.
