HKS blow off value
Old Feb 2, 2006 | 12:38 PM
2vonku's Avatar
HKS blow off value
Do you lose power or lose boost by just installing the bov without any tunning. Thanks.
Old Feb 2, 2006 | 12:46 PM
Warrtalon's Avatar
You don't tune for a BOV. You add a BOV to properly hold higher boost. The HKS SSQV is not recommended on an Evo unless you are running a speed density setup.
Old Feb 2, 2006 | 01:07 PM
btuneallen's Avatar
What Warrtalon said lol.
Old Feb 2, 2006 | 01:14 PM
Max Speed's Avatar
whats speed density setup?
Old Feb 2, 2006 | 01:18 PM
2vonku's Avatar
Thanks...
Old Feb 2, 2006 | 03:05 PM
mhx's Avatar
mhx
so its not recommend to install any aftermarket BOV? I am interested in getting an 06 IX and plan to get exhaust, MBC,flash,filter..
Old Feb 2, 2006 | 03:24 PM
Aux.'s Avatar
Why is it .... why a BOV ? Why does every newb ask about a BOV ? Why not boost gauges or cams or cam shafts. Man, you guys need a role model. THE WORLD DIDN'T START AT THE BOV!!
Old Feb 2, 2006 | 03:32 PM
lvNVevo's Avatar
This is what happens when you have movies with overly dramatized action sequences in them. Did you hear how f'n loud they played the BOV sound in F&F......Every person/ricer that had or is purchasing a car with turbo is putting those stupid things on their car. Yes i will admit i own an HKS SSQV and have used it on my evo.....but there is a good reason i dont have it on now an wont put it back on...... And as for a role model most of them have one "Paul Walker"
Old Feb 2, 2006 | 03:35 PM
Rnm's Avatar
Rnm
Keep your OEM DV. It holds boost just fine.
Old Feb 2, 2006 | 06:21 PM
EVOGOD21's Avatar
hks bov sucks!!!!!!!!!!!!!!!1
Old Feb 2, 2006 | 06:26 PM
Curt@MrLed's Avatar
Former Vendor
hks sucks on our cars... fast and furious thats why...
Old Feb 2, 2006 | 06:52 PM
slo4g63's Avatar
So that means you are/were one of those people too???
Old Feb 2, 2006 | 07:25 PM
trinydex's Avatar
i don't know about hks bov not being recommended on our cars... i think it's all about recircing and not messing with the knob settings. there have been plenty of people that have cited no problems with hks recirced. then there are a lotta idiots that have managed to **** it up.
speed density is a different type of air "metering" system. and i say metering with quotes because it doesn't really use a meter like the maf. it instead takes the temperature of the air and the pressure in the manifold and then does a mass calculation and feeds your car fuel that way instead of measuring how much air passes through a meter.
this method of air "metering" has its advantages and disadvantages. one is that you don't have to wrorya bout metered air... the air is calcualted at the intake manifold so what you smell is what you get. you can search the vishnu forums or the evo9 ecu tuning thread on why speed density may be inferior to air metering.
speed density is the choice of stand alone ecus... so most all stand alones are capable of going speed density. maftpro is another way of going speed density. search these topics and find out more.
