Evo GeneralDiscuss any generalized technical Evo related topics that may not fit into the other forums.
Please do not post tech and rumor threads here.
you are used to the power now so you think it is geting slower. Can you go without driving the car for a week or two? If you can then when you drive it after the pause you will feel how fast it is.
Mine felt same way, but now I see boost hit 20psi and I am like boring. I did comp test last week 180 straight thru and I swaped plugs.. as boost goes up the rpms take a while in a low gear so i am thinking it may be clutch 33k on stock evo 8 clutch
