Help *Radio Dead* Help
Hey, i was down in my garage using a voltmeter checkin my fuses under my steerin wheel when i noticed my radio didnt work. It doesnt even power on. I didnt probe anywhere in the cubbyhole "where my tt was" or where those factory gauges come in 05's. I checked every fuse inside the car and radio ones in the engine bay all are good besides my heated mirror one which i didnt even know i had. Whats wrong? i did the best i could for checking wires goin to the headunit and lookin for cracks or unplugged wires. Stock headunit, didnt touch anything inside besides to hook up my boost gauge light which was a few months ago, and my tt which was longer than that. Help me get it workin!
p.s. how do u get the plastic moulding off that surrounds the headunit and the fan controls, i had 4 screws out. The two on the bottom holding the cubbyhole, and the two behind the knobs, whatelse is there. If i find that out ill check behind the radio, and everything.
***** OH *****
btw, the clock doesnt work either at all or the keyless entry that the car came stock with. No flashing lights, and it doesnt lock or unlock it. Also my trip odemeter resets itself everytime i start the car
help me out, i dont wanna have to go to my mitsu dealer and get hassled
***** OH *****
Sounds like a Fuse or you didn't connect something back. Even if a fuse looks good doesn't mean it is, just replace it and see. Oh and did you connect the battery back? If all else fails time to buy a new deck!!!
I believe those are the only screws holding the two panels in. The rest is pull and pray you don't break the tabs off. Should be ok though, I've pulled mine atleast half a dozen times and the clips still held good.
isnt there a fuse for the radio and clock under the hood? im rpetty sure it is in the fuse box in the bay surounded by the yellow thing i think its 2 10 amp mini fuses ivce blown them out before
