i have no clue
i have no clue help!?!?!?!?
just got my ecu back from dynoflash and my car wont boost over 1 bar...it wont even go to stock boost any ideas?
You mention "took it around the block". Did you let the engine warm up for a little while? I remember when I first put my boost gauge in and it only registered 12psi for the first few miles in cold weather, I thought I'd screwed something up...
Originally Posted by IXmr321
nothing changed i plugged it in took it around the block and it'll hit .8 bar and stick
Originally Posted by ibanez_926
try unpluging the outside 2 connections on the ecu harness or unhook the battery to reset the ecu to see if that solves anything
Originally Posted by Rnm
Check for boost leaks.
its feels like its gonna be faster but the turbo doesnt spool up...if that makes sense
i can punch the gas and right up until it stops climbing on boost it feels like it pulls more but as soon as it hits .8 bar it just falls on its face
are you using the greedy spec 2 ebc? When you first start up the car you have to interact with the unit before it will use your boost settings. Failsafe at 14psi when first turned on. Just a thought.
