needed advice about stock brakes??
i have about 25000 miles on my evo 8. i had my rotors turned about 3000 miles ago d/t excissive warping of my rotors both front and back. it took away the vibration in the steering wheel temporarily but is already back again and stronger than ever. i dont want to spend a fortune on new brake components, but dont want to resurface rotors again as it obviously didnt help out from the last time it was done. i have done some research and have only come to the conclusion about proper bedding techniques w/ new equipment. any suggestions?? thanks.
one more time with feeling:
Please read-
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
It will save you money.
Then read-
http://www.stoptech.com/tech_info/wp_bedintheory.shtml
Then -
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
Try bedding in your pads again and see if it goes away. Another thing is not to leave your foot in the brake pedal when the rotors are hot, this will cause damage also.
Good luck...
Please read-
Then read-
Then -
Good luck...
Please read-
Then read-
Then -
Good luck...
Please read-
Then read-
Then -
Good luck...
yeah ill try the bedding and if that doesnt work, replace parts. is it possible to keep the pads and just replace the rotors as there is plenty of pad left?
Smike
63
Apr 29, 2019 07:27 AM
EVOlutionary
90
Feb 8, 2016 09:45 PM
4g63xawd
62
Jan 6, 2016 03:25 AM
atombomb33
11
Sep 13, 2007 01:02 PM
