WHP and WTQ correct?
I just recently installed HKS 272/272's, AEM gears, and SAFC II to my EVO. I am making about 292WHP and 241WTQ with the AFR in the high 11's (on a mustang dyno). Before we put those parts in, I had we put in on the dyno and it was making 258WHP and 234WTQ with the apexi power intake, 3"TBE, and Greddy boost controller(20psi). The tq only gained about 7WTQ in total but it seemed that the stock cams dropped early whereas the HKS kept pulling to the flatter 241. Can you guys please tell me if these numbers are correct? I am also going to the track this friday, what do you think I will run with this set up?
Originally Posted by EVOlution561
so what should I do to get the tq up? 750cc injectors and a fuel pump so I can get the boost up to around 25?
Who tuned your SAFC? Who's mustang dyno?
Some more boost would help with your trq number. You could at least go to 21psi, that will help with peak trq.
Injectors will make tuning the peak trq area a little easier with the SAFC. You can do it with stock injectors, it's just a little trickier.
You gaining 30wtq over the curve area is a good improvement, although we don't know what shape your car was in before. (If it was tuned or not)
You've been asked already - who tuned it and whose MD is it? You shouldn't already be to the point of adding major mods like cams if you don't even know anything about tuning. You should have taken it slowly and learned first, because right now, your car isn't in good shape.
BEKevo
Feb 11, 2013 07:56 PM
ill-luzion
24
Mar 22, 2007 05:12 AM
razorlab
25
Dec 5, 2005 01:53 PM
