getting tuned
getting tuned
can anyone post a reply who has gotten a flash especially from al who does not have a boost controler. What did you get your boost up too and what do you hold at redline. I was thinking maybe taken this restrictor pill out. The reason i am asking is a have a hallman mbc but i dont want to use it i am against all boost controller with no safety cut off. I have one for sale by the way. thank you
Well, the only safe way to run the mbc would be a boost gauge. My friend had a mbc and the dynoflash boost control with no gauge and it was supposed to be set at a 21-22 spike and settle to 20 but when we got a gauge in it was spikin to almost 2 bar. I don't know how accurate the boost control will be but the best bet is to use the mbc/gauge/and als flash to make sure the boost is what you want it at.
If you decide to sell the mbc, good luck with your sale.
Just use the Hallman MBC. There is no need for a "safety cutoff." The only safety cutoff you need is your brain so that you don't turn it up too high for no reason. Once the boost is set, it doesn't just randomly shoot up high. It may spike a little higher in colder weather, but that's why you monitor your boost gauge and adjust accordingly.
Boost-control from the flash gives you around 20-21psi, and it holds 20psi most of the way to redline before tapering off, but not as bad as stock. I wouldn't suggest removing the pill. That's WAY more random than having a good Hallman MBC in control of your boost.
