Speedo Gauge Bulb (w/pic)
I was wondering why my speedo and tach needles were invisible....
So I tore our the cluster and both bulbs are fried (see pic)
Anybody have this happen?
Where should I get new bulbs?(I will do a search, but will gladly take suggestions)
Thanks
Thanks
rcheung:
Thanks for the info, do you know the part number for the smaller bulbs in the cluster. Ive been searching for the past hour and I'm about to scream. I went to the stealership to ask about the bulbs also, the large bulbs (in the pic) cost $6 each(holy %$#%), the smaller bulbs(which there are about a million of) cost $7 each(double holy %$#%). So if anyone has the part number for these, or another source, that would be appreciated.
Kitw:
Yes, the condoms are removable, although mine are currently "burnt" on
Kitw:
Thanks
Thanks
http://www.lightrikz.com/misc.htm
Originally Posted by kitw
Is that condom removeable, and does it make a noticeable brightness difference?
I'm sick of the too dim gauges at night.
Yes, it will make a noticeable difference. I removed all of mine and found the trip/odometer display to be almost too bright.
If you referring to the clear smaller bulbs with the black base that part number is
MN134599
MN134599
rcheung:
Kitw:
Kitw:
