How much for CAMS to tuned
How much for 264/264 camshafts and cam gears to be installed and tuned properly? Do i need walboro fuel pump?! Should i change the timing belt as well? Around how much?!
I only have turbo-back right now, 04 evo btw.
Can someone estimated the total? I don't want to buy cams and gears just to let them sit there
thx for your inputs
thx for your inputs
Originally Posted by evocanival
u should most definatley get a fuel pump, and the tune is around 450. not sure how much for install.
Should of done it myself...
You have a lot of other mods to do before cams. There's no reason to ask us these specifics either, because it depends on the shops around you. It's highly unlikely that the place that installs your cams and cam gears (why cam gears?) is also going to be a known Evo flash tuner. How did you plan to get tuned? It's not just something that anyone can randomly do - they have to actually have flashing software for the Evo. If you live near a well-known Evo flash tuner (there's not even 10 in the country I don't think), then have them do all the install and tuning work - they will charge you whatever the normal price is.
But don't forget all the other mods you should have gotten or should be getting before even thinking about cams.
