Evo IX GSR or MR?
#32
Originally Posted by wacboyjulian
The BBS Rims are lighter
they mention it on the motor trend article
"The MR's BBS aluminum alloys are each 2.8 pounds lighter than the Evo VIII's and RS's standard Enkei's, and when accelerating (or decelerating), a rolling wheel presents more effective mass than a simple scale can measure, multiplying the value of the BBS's weight saving." ~ Motor Trend Article
#33
Originally Posted by BoostinEvlution
Actually, the aluminum hood is only on the RS and the MR.....
#34
Originally Posted by Andrew LB
I also prefered the SSL package on the IX which includes a far better sound system,
#36
Former Vendor
Here is my personal experience. The MR out of the box is sweeth the 6 speed pulls hard in every gear, handling is great. If you are going to mod, get the GSR. I road race and drag race frequently. The 6 speed cannot take the high horsepower and shifting get very sloppy at higher rpms. I Shattered the input shaft on the 6 speed and have since replaced it with a shepherd built 5 speed. I also took out the ACD, i cracked that in 2, went back to the regular center diff with limited slip.
So bascially, if youre going to stay stock or close to stock stick wht the 6 speed, but if you go all out go i.e. big turbo, stroker, etc go GSR, atleast you will already have the 5 speed and you can just throw out the ACD and put in a limited slip non acd unit.
good luck you will be happy either way
#38
Topic creator, I thought you said that you didn't like Evo IX and that you were happy with your STI at clubwrx.net? Its pretty funny seeing you post here as I would never have thought you would even try to drive an Evo considering how much of a negative opinion you formed about it over there. If you consider the seats to be uncomfortable, I suggest you keep your fatass in the STI and be happy with what you got.
http://www.clubwrx.net/forums/showthread.php?t=132969
#40
#41
I think that's hilarious that the world is so big yet performance car society is so small that we can track each other's movements from forum to forum (i.e. evolutionm.net, clubwrx.net, nasioc.com, etc...)....
That's y I've got different user names for every forum out there!
HA!
HA!
#44
whats an evo gsr, i thought it was called an rs, is the gsr evo, the 5sp model of the year of the evo IX's?
im also reading bout the ssl model?
im confused, i want to trade my rsx in for an evo, so im tryin to learn
#45
There are three models. RS, GSR, and MR.
SSL is a packge available for the GSR, it stands for sun sound and leather.
More details can be found via the Search button.
