Ecu Wiring
Ecu Wiring
ive got the zeitronix wide band kit, ive got the break down as for as what wires on the kit go to what. but some im lost on, one is the simulated narrowband o2 output. where does that tie into the ecu at?
also it looks as though several wires from the zeitronix harness are not used if i didnt get their boost sensor and egt sensor. if this belong in the how to forum then some one can move it for me but just think it would get more responses here.
so essentially if i didnt get the boost sensor, egt sensor, and the display then it just;
pin 1 red to 25 on ecu
pin 3 green to 58 on ecu
pin 7 black to 26 on ecu
pin 10 grey to 84 on ecu
and 11 or 8 brown to 92 on ecu
thanks for the response
white= analog output- not required in your application
blue= USER Input 1- not required in your application
brown= sensor ground for boost sensor- not required in your application
purple= simulator for front O2 sensor- not required in your application
