My First Launch!
Old Mar 9, 2006 | 03:51 AM
dsmfan95's Avatar
If you dumped the clutch you shouldn't get a burned clutch smell.
Old Mar 9, 2006 | 03:56 AM
Wicked's Avatar
I went about 50k miles, with over 40 hard launches.
Something to remember:
Dumping the clutch saves your clutch
Slipping the clutch saves your drivetrain
Originally Posted by SKILMATIC
Damn! I wonder how many times you can do that till you need another clutch? I knwo my friends 03 GSR went up to almost 35000miles till his clutch started to go out.
Old Mar 9, 2006 | 09:46 AM
3000ways's Avatar
I thought I did my first launch too, was like YES, my first launch in an EVO time to go to the track, 2.0 60ft times all night
Take it to the strip and see if your really launching it correctly
Old Mar 9, 2006 | 09:52 AM
eve-slow's Avatar
Ya you should
Old Mar 9, 2006 | 10:04 AM
zgodfathera's Avatar
so which is better dumping the clutch or slippin it?
Old Mar 9, 2006 | 10:05 AM
jred321's Avatar
i did my first launch the other day too, it didn't smell like burnt clutch though. just a small chirp from the front tires (im on winter tires still with a bit of sand on the road) and off. whether it was right or fast or whatever, who knows, but it sure was fun i don't plan on doing it very much though, clutches and other driveline parts are too expensive
Old Mar 9, 2006 | 12:20 PM
Sleeper2G's Avatar
how is your burnt toast air freshener?
Old Mar 9, 2006 | 12:24 PM
cloudy's Avatar
Originally Posted by eve-slow
Ya you should
Not really.. Dumping the clutch in short terms = Less wear on the clutch but more wear on the tcase and stuff.
Slipping the clutch = Less wear on tcase but more wear on clutch. Id personally rather replace the clutch then a Tcase.. And if you get good enough at slipping it, you will hardly ever smell the clutch.
