Wrong springs for MR
Old Mar 10, 2006, 07:47 AM
lan_evo_mr9's Avatar
I appreciate all the help and input you guys have given me. It seems like I'm probably going to have to return the springs(if they will let me)and buy a set of works or swift. It's just annoying to have to do double work and all. Oh well, thank again.
Old Mar 10, 2006, 09:11 AM
slow_evo's Avatar
Idk about the MR but I have had my Hotchkis springs on for about 11,000 mi and absolutely nothing has happened. It still rides exactly like stock and handles exactly like stock if not better.
Yes putting aftermarket springs on a stock strut is going to cause premature wear on the strut because the strut was specifically designed for the stock coil but it varys on the type of spring. Some more, some less. I decided to go with Hotchkis because it is the CLOSEST spring rate to the stock springs. Some manufacturers do not even give you a spring rate (like Tein I think)...so how you are supposed to know?...I have no idea.
But so far so good. Hope this helps.
Old Mar 10, 2006, 11:43 AM
Well here's the good news. I stopped by AMS to ask them about the situation and they said I had nothing to worry about and that they are running several MRs on this same set up with no problems. They also said that if anything did go wrong that they would look into it for me. That is a huge load off my shoulders.
Deano_Engineer_
Nov 7, 2016 04:31 PM
Deano_Engineer_
Nov 7, 2016 03:59 PM
suddoth1
Sep 11, 2016 06:54 PM
dnyce
19
Nov 25, 2012 04:37 PM
Fast_Freddie
12
Aug 2, 2011 07:55 PM
Quick Reply: Wrong springs for MR
