What's wrong with my stock evo???
I have a 05, and my boost was pritty normal until I start changing out exhuast manifold and tbe and now I get the same problem but I've been taking it easy for a little bit since part change out. went thorgh a couple of tanks of gas and the ecu has since adjusted to the new air flow. I think your can is perhaps adjusting to whatever else you have done.
Ok good i'm glad i'm not the only one. I changed out all my plastic hoses to rubber the whole way and it still does it. Oh and for all you guys that are telling me to check my ic hoses and if I purchased the car new. Check the first post and you would see the car is brand spankin new.
Originally Posted by 8urv8
Use the regular vacumn hose all the way. I don't like that plastic stuff that comes with the gauge, plus it doesn't seem to hold up to under hood temps as well as the other stuff.
Originally Posted by althemean
with the SW gauges you need the plastic line to connect to the back of the boost gauge. It has to be installed. At least just a small portion of it.
