stock Evo 9 BOV leaks exactly at 26-27psi
Last night I did some boost testing after I ran the Evo 9 at the track and found out that the stock BOV (metal one) leaks at 26psi-27psi.
I recorded a few runs and I did some testing and found out that If I punch it in 5th gear at 60 mph the boost goes to 26psi and sounds like pshs pshhh pshhh pshh several times while it stays at 26psi for a few seconds.
The readings were made on my Defi BF imperial and using the DEFI controller as well(it has a memory card that can record your boost for up to 30 sec then duplicate/play it on the gauge)
By the way, planning on getting a UICP this week on the Evo 9. Any suggestions?
I don't think I will upgrade the BOV at all since the stock BOV hold 26psi and I normally don't run 26PSI. I was running 3 gallons of 101oct last night so I allowed myself to run those levels.
EvO 9 mods:
3"TB,MBC,Dynoflash mail-in,CAI
Carlos
EvO 9 mods:
Carlos
the only real way to test is to do a pressure test on your piping, driving around and listening for leaks isn't a reliable method.
has anyone tried to "crush" these BOV's like the 1g DSM valves yet?
I agree that pressure testing is the only sure way to determine when it leaks. FYI - I found the plastic stock evo8 bov started leaking at 19psi.
Originally Posted by phatman2600
What does a leaky stock BOV feel/sound like?
I don't know to explaine it better but it is a very unique sound, it leaks when you are building boost.
Carlos
Originally Posted by E VOL IX
Yo man go with the perrin uicp.. You can get it in 3 diff colors, doesnt need a smaller battery and it looks awesome.
To be honest, I don't think I will be running the 27psi for much longer, just until the 91-101 gas mix last on my tank.
Carlos
ksattic
Apr 2, 2008 01:36 PM
jcsbanks
12
Oct 29, 2007 01:21 PM
TKVK1
Apr 15, 2006 05:39 AM
