where in vaccum should my gauge read at idle
Old May 26, 2006, 10:54 AM
  #31
Liquid-R1's Avatar
Originally Posted by EvoRicer
Im in NorCal, my Vac at idle is 19-21 inhg. Is that normal for me or is something wrong? I have a Defi BF boost gauge. Also it spikes to around 24-25 inhg when I let off the gas...normal?
That's about right... I read 19-21 when I had stock cams... When I put in 272/272's it went to about 13-15... WHen the A/C on, it goes to 10...
Old May 26, 2006, 02:27 PM
  #32
steevo's Avatar
I must have 272's just like my tuner suspected. My vacuum does the exact same thing. That's good news for me.
Old May 26, 2006, 03:28 PM
  #33
LoCo4's Avatar
19 or so with my Sterwart Warner boost gauge.
Old May 27, 2006, 09:30 AM
  #34
Boosted GP's Avatar
I get 15, works 269 cams and an altitude of 5500Ft
Mike
Old May 27, 2006, 02:08 PM
  #35
vwjeff's Avatar
Stock cams, Autometer, 17 to 19 at idle, and 15 with a/c on. 15 psi in 1 through 3, and 19 in 4 and 5.
Old Jun 25, 2007, 02:30 PM
  #36
JsEvo04's Avatar
15 with cams 20 with none
Old Jun 25, 2007, 04:06 PM
  #37
gsrboi80's Avatar
mines like 14-15 with 272s
Old Oct 5, 2007, 11:33 AM
  #38
Evo2wIsh4's Avatar
I had the Megan Manifold and the Megan o2 housing just installed and I also have the Cosworth Cams. I am using the Prosport Premium gauge and Mine reads around 10-12 is that normal? Before it used to read around 18-20
Old Oct 5, 2007, 11:39 AM
  #39
E\/0IXG$R's Avatar
Prosport gauges stock cams, 19-20 at Idle. Yes I can confirm that it goes up to 16 or 15 with the AC on high.
Old Oct 5, 2007, 12:17 PM
  #40
72Tornado's Avatar
Like most others, 19 at idle, 15 with the A/C on. Stewart Warner gauge.
Old Oct 5, 2007, 01:01 PM
  #41
tdz16's Avatar
I don't know if you are running a vac line through the firewall to the gauge but sometimes they get pinched at the firewall and will expand enough to read right at boost but not in vac. I would just double check that first.
Cams with play with vac at idle as well big time depending on how hairy they are.
Good luck,
~Tom
Old Oct 5, 2007, 01:10 PM
  #42
Evo2wIsh4's Avatar
Mine is a digital gauge. So I am not sure whats going on. I re-ran all the vacuum lines and put brand new ones and still the same reading. And It happened after the o2 housing and manifold install.
Old Oct 5, 2007, 02:27 PM
  #43
riceball777's Avatar
stock i was at 19-20
now with hks 272's i'm at 14-15 at idel
Old Oct 5, 2007, 02:32 PM
  #44
Evo2wIsh4's Avatar
its provably is the combination of everything. I am going to double check it on sunday when I got get the car Dynoed and tuned. They are going to gook up their data logging equipment so lets see if they match.
Old Oct 5, 2007, 02:51 PM
  #45
meckert's Avatar
Interesting...but..vacuum doesn't fluxuate with altitude unless the idle speed is reduced......or mixture changed (;-), more likely the issue) I think that would be paramount to saying thinner air moves slower then thicker air...( dont think physics allows that) could be different vacuum in stock cars/cams as well...depending on cam timing, hence the need for cam gears...given the opportunity to tune a car paying attention to the vacuum alone...tune to the highest vacuum for a given idle speed... back in the day, thats the way you tuned for idle richness...by vacuum, going for the highest vacuum pulled by adjusting the mixture screws then idle..
Quick Reply: where in vaccum should my gauge read at idle
