need to know where I can get DiaQueen fluids
#31
www.mitsubishiparts.net/catalog/?section=457 it is $35.05 per can...
#35
I was speaking with Shep a while ago about building my TC and what not and he does recommend Redline Heavy Shock Proof in the TC.
He wanted me to make this very clear on Evom since alot of people are misinformed.
#36
I believe 3 qts in the tranny, then 1 qt each in the t-case/rear diff. Correct me if I'm wrong...
#37
#38
With BG syncroshift II for the trans?
#40
Originally Posted by Doogie Howser
I though Diaqueen was only meant to be used for t-case and rear diff?
#41
However, I was wrong about the 1qt. Zmeli said that it's 750ml, but I don't know how far off that is from 1 qt.
#42
Yes, exactly. I didn't specify the fluids, because I was responding directly to mdsevo4.
750ml = 0.7925162 QT
1 QT = 946.3529 ml
You got me curious
#43
Originally Posted by zmeli
True True this is VERY TRUE listen to the Experts that fix the boxes that Redline Destroys!!!!!
With Heavy Shock Proof you wil be fine.
#44
1000ml = 1.056688 QT
1 QT = 946.3529 ml
You got me curious
1 QT = 946.3529 ml
You got me curious
#45
i used redline in my 03 trans, t/c diff. 3months later my t/c was whinning really bad and ha d it rebuilt under warranty. 3months after that my trans started grinding 4th gear, had it rebuilt under warr. the dealer used BG syncroshift in the trans, diaqueen in the t/c and diff. was perfect after that.In my 06 BR350IX#005 i use BG SS in the trans and diaqueen in the t.c and diff. shifts like butter.I will never use any other combo
