I need some help on ideas to secure my subwoofer box in my trunk.
Ok... so i've got a pair of 12" boston acoustics pro series subwoofers and a SoundStream Reference 500s amp running at 1 ohm and the subs are mounted in a sealed enclosure. I had them previously in my Audi A4 and luckily the Audi had 4 bolted in metal hoop type attachments on the floor of the trunk for using their tie down cargo net, etc. I ended up putting two O ring bolts into both the left and right side of the box and used a steel quick release thing from home depot to secure the O rings to the tie downs built into the car.
Now... of course the Evo doesn't have tie downs on the floor of the trunk and i'm trying to figure out how i can secure the sub box from moving around, plus i'd like to keep a similar configuration to the Audi since i can easily remove the sub box to make room if i need to carry something or if i'm at the track.
Have any of you drilled holes into the metal floor of the trunk under the carpet to make such a tie down? I'm not sure what is exactly underneath the area where i'm considering doing this and i'm sure the fuel tank is further foward under the rear seat if i recall correctly. I just don't want to punch a hole in the tank and cause a disaster.
The box itself is 28" long, 15" high, and 12.5" deep. Here is a photo of it when i had it installed in my Audi.
I'm not sure where i'll mount the amp yet either. But i'll deal with that in time.
Thanks in advance!
-Andrew
Thanks in advance!
-Andrew
Metal "L" brackets from hope depot screwed into the back seat and top of the box. or if you dont want to drill, you can give velcro strips a shot although your box probably weighs too much for that..
I cut two sections of 3/4 MDF and glued them together. Covered with matching carpet and squeezed it in between my box and wheel well. Repeat for other side. Cheap, quickly made, no drilling required and keeps box in place.
I used 2 bolts with eyelets and screwed them into my sub box, then I got some bungy cord and secured it to the eye bolts and to the little holes in the upper part of the trunk, works really well.
Originally Posted by slow_evo
Velcro?
I've been McGeyvering (sp?) my car all day today. Hard wired my Valentine One radar detector and a nice remote hidden display a friend tore apart to make it like 1/6 the thickness. Also took out the ashtray, spent a ton of time with the dremel and mounted an I-Pod dock inside. Its amazing and completely out of sight unless i flip it open and click in my i-pod. I'll be posting photos and a writeup tomorrow after the JB-Weld is completely set and i tear the dash apart to wire it to the head unit... (and change all my climate control/clock/cig lighter LEDS to red.
ludacrick
16
Nov 2, 2006 01:08 PM
Andrew LB
Mar 30, 2006 01:18 AM
DjDoubt
Apr 27, 2004 11:40 AM
