Cam with no tune?
Old Mar 24, 2006, 09:38 AM
4WS Tuning's Avatar
Cam with no tune?
im getting a good deal on a 272 HKS CAM for my car....would i be able to install it without having a tune? i know im not going to have the full potential and my idle will probably be blah....
thanks
Old Mar 24, 2006, 09:46 AM
8urv8's Avatar
I wouldn't, then again I am not an expert on tuning. I couldn't tell you if it would be bad for the car or not. I just believe in having the proper tuning to match your mods so you can get the most of them.
Old Mar 24, 2006, 09:55 AM
4WS Tuning's Avatar
definetly right, but i dont want to waste money on getting 10 tunes....i just rather have it in the car than in the corner of my room
Old Mar 24, 2006, 09:58 AM
Rnm
Rnm's Avatar
I'd get it tuned.
Old Mar 24, 2006, 10:02 AM
4WS Tuning's Avatar
there goes my closet space!
Old Mar 24, 2006, 10:11 AM
frenchy99's Avatar
if you are worried about the idling then get cam gears too
Old Mar 24, 2006, 10:14 AM
05WhiteEVO8's Avatar
You will be fine for a little while just let your ECU learn it, and semi expect fuel cut if you run it all the way up to 7K. I installed my 272's and had no problem at all. Remember the ECU does learn so you will be fine.
Old Mar 24, 2006, 10:17 AM
Kee1pride's Avatar
am i wrong or has HKS not even made cams for evo 9s yet? are you putting evo8 cams in?
@_@
Old Mar 24, 2006, 10:36 AM
Rnm
Rnm's Avatar
He intends to only put in the HKS 272 exhaust cam which fits the 9's.
Old Mar 24, 2006, 10:43 AM
Widebandphillip's Avatar
you're fine
Old Mar 24, 2006, 01:26 PM
Stinkapuss's Avatar
Put it in.
Old Mar 24, 2006, 02:09 PM
anjapower's Avatar
my car ran fine with cams in and no retune...granted it didn't run as well as it did after the retune (very rich), but it wasn't unsafe. I was untuned for about 1.5 months.
Old Mar 24, 2006, 02:12 PM
32 psi daily's Avatar
I'm not 100% sure but 272's may make your car run a lot leaner than you would like.
Old Mar 24, 2006, 02:26 PM
sonicnofadz's Avatar
Putting in a set of cams (in theory) should not interfere with your A/F ratio. What does a bigger set of cams do? Allows more air to flow through into the head due to a change in lobe duration and lift. Since the Evo (like most modern cars) has a MAF sensor that calculates the flow of air into the engine, the ECU should account for the extra air and add more fuel accordingly. I suppose that overlap might allow some air to escape the combustion chambers, but in this case that would only make the car run rich, which is not a bad thing (won't be as powerful as it could be however).
Old Mar 24, 2006, 02:29 PM
Evo_Jay's Avatar
thanks
Your idle will be fine because the intake cam isnt messed with.
Quick Reply: Cam with no tune?
