Megan Racing TBE
#76
Originally Posted by Zeus
That's incorrect... there was a run that didn't fit well on the 05's... and that was Megan's (poor) solution for that run. They were reimbursing people to have O2 bungs welded 180 degrees out. 03'-04's are fine. I still run the original design on my own 03' with no issues at all. The pics I posted are of the new re-designed 05'-06' product.
Your PM has been returned.
#77
Originally Posted by High_PSI
OHHHHHHHHH MAN that looks good, I will wait for the Turbo Back, if it is $550 then there is no way I can't buy that exhaust. Sound clips?
http://www.youtube.com/watch?search=...&v=bapBpbrjfqA
#78
Originally Posted by Peteypab2133
Here is a sound clip for ya lol when my boost gauge was actin up... but it is a Megan Racing TBE with a few other mods
um, i don't think that is it.
looks like little girls to me. You ought to be ashamed of yourself
#79
haha thats the smoothest response i couldve gotten, but now that the feds are knocking on my door ill brb... here is the real link lol
FING COPY/PASTE DOESNT DO WHAT I TELL IT TO!
http://www.youtube.com/watch?v=I6f98VvYa14
#80
Originally Posted by Liquid-R1
Are you running a 04? And is that Megan's full exhuast? If so, no, that's incorrect. You need to rotate the mid-pipe 180 degrees and attach the O2 bung to the hole on the test pipe... Otherwise, the exhaust won't line up. You'll run the mid pipe close to the driveshaft and the metal part of the fuel tank. And if you try to correct that by moving the exhaust bracket over to the other side, you'll end up touching your bumper and melting it...
That's incorrect... there was a run that didn't fit well on the 05's... and that was Megan's (poor) solution for that run. They were reimbursing people to have O2 bungs welded 180 degrees out. 03'-04's are fine. Your PM has been returned.
d
#81
Originally Posted by donour
If you read my post again, you'll see that I'm actually quoting that picture from Dr.SS . That isn't my car or exhaust. I just wanted to make sure that folks were mounting their 02 sensors below the horizon as bosch and other companies specifically dictate that you should not do that.
Well, it's not 180 degrees out, it's more like 90 degrees out. No need to split hairs though.
d
d
Yes Megan does mount the O2 bung at 4 o'clock. I was a bit concerned when I bolted it on over 2 years ago too... that was then, and it still seems fine now.
#82
Originally Posted by TTP Engineering
This is correct. This is probably one of the first new version catbacks available and is totally redesigned from the routing to the hangar type and locations. It appears this new version exits JDM style at an angle. Totally different exhaust.
#83
As for the exhaust, I haven't had any problems with it to date... Only thing is that I'm not sure how well the mount will hold up the current way I have jury rigged up... I'm sure that Megan will come through in taking care of it as evident in previous post about their excellent customer service...
#84
d
d
Gary@MellonRacing
Jun 21, 2010 07:59 AM
Massappeal
Evo X Dyno Results
29
Feb 2, 2009 03:23 PM
Go_Lancer_Go
16
Oct 6, 2008 07:09 PM
