Is this oil ok to run in my rear diff, X case, tranny?
I changed it to the OEM diaqueen fluid for the rear diff, now im gonna change my transfer case , i found the drain bolt but am having trouble finding the fill bolt ,
I went through this the other day with the lancer shop. I believe that there is diaqueen which meets the tranny specs and then there is diaqueen super gear lube for the MR ACD. The name differences make it hard to tell them apart but can anyone confirm that the MR center diff lube is different than the standard center diff. ACD vs. non-ACD
This is straight from the Evo Moto site
"We strongly suggest running the OEM fluids in the EVO 8 transfer case and the Rear diff. What we have here is a jug of GL5 SAE90 OEM EVO MR Diaqueen Mitsubishi fluid. This fluid is NOT to be used in the tranny, we suggest using the BG syncroshift for the transmission."
I ordered the same part # from the lancer shop and they sent the 75 80 stuff.
i filled it w/ what the dealership told me, they told me to use Valvoline 75w90 in both the tranny/t-case, so if anything goes wrong, they better be replacing it under warranty, didnt have to deal w/ the acd, so that stayed the same
Karash
Apr 30, 2005 12:20 AM
