FQ400 Question ...
#31
Originally Posted by her0
I noticed that suspension components are not listed. Anyone know if FQ400 handles any differently from the standard evo?
Originally Posted by Spooling Dreams
wait wait wait,..... if i want my IX to handle as good as the FQ in that video,.. I will need a AYC??? ... I thought for my IX to handle as good,.. that MR's suspension, (or good aftermarket shocks) would do the trick or close to it.
A properly set up car with good, track-oriented alignment can rotate just as easily (and even more predictably). If you invest $2,000 in a good coilover suspension and actually find someone who knows how to properly choose appropriate spring rates, adjust damper valving, corner balance, and fine-tune the suspension, you'll totally eclipse the handling of a stock Evo VII MR. There's nothing magical about the stock MR suspension or S-AYC. Good old fashioned suspension tuning will get you much further.
Emre
#32
Originally Posted by spdrcr456
i think this is a joke but cal me stupid,i dont get it and if it isnt a joke .......huh![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
#35
Originally Posted by PapitoEVO8
Lancer Evolution VIII MR FQ400 parts list:
Custom built Garrett GT Dual Ball bearing Turbocharger
Owen Developments custom manufactured cast Stainless Steel Exhaust Manifold and Exhaust Elbow
Omega Forged Pistons
HKS Forged Con Rods
HKS 680cc Injectors
Zytec ITP116 High Pressure Fuel Pump
HKS 1.6 mm Steel Head Gasket
Motec M800 OEM ECU
HKS Iridium Spark Plugs
Jan Speed High Flow Sports Cat
Alcon competition derived 240 mm high clamp mode, heavy duty clutch complete with Cera-metallic 6 paddle sprung centred drive plate
HKS High Strength Head and Big End Bolts
Alcon Mono6 Brake Kit incorporating Monobloc 6 pot road caliper with 343 mm curved vein Disc on a Aluminium mounting bell assembly with Ferodo DS2500 brake pads
Ralliart Aero Mirrors
Carbon Fibre Front Lip Spoiler
Carbon Fibre "Sharks Tooth" Rear Vortex Generator
PIAA High Performance Light and Wiper Upgrade
Gloss Black Team Dynamics Lightweight Alloy Wheels
HKS Forged Con Rods
HKS 680cc Injectors
Motec M800 OEM ECU
#36
Originally Posted by Kayaalp
The difference is that the FQ-400 has forged internals, a huge turbo, and all the associated mods needed to get the most out of them. The 400 crank HP that this set-up puts out is VERY mild. There's literally tons of room to grow. Just by cranking the boost, you can safely pass 500 crank HP.
Emre
Emre
A FQ-400 is not a 600 hp car basically... it's a 400 hp car that costs over $50,000
An Evo IX is not a 400 hp car.... but it can be for less than $2,000 in mods... so the grand total is about $36,000 more or less to get a "400 hp" Evo.
That's the point I'm trying to get across.
#37
What kind of numbers does an FQ-400 (as they are sold) put down typically? That would be interesting to know. From that point we can better compare our mildly modified (comparatively) VIII/IX numbers. Anyone know?
#38
Originally Posted by cdavy
No CAMs? Did I miss something? If not, that goes against all the discussons here in not upgrading the turbo and keeping stock cams... Interesting to hear it can flow to 600hp with more boost, stock cams?
![Help Me](https://www.evolutionm.net/forums/images/smilies/help.gif)
#40
I just could not imagine the FQ-400 build-up goes through all those mods and left the CAMs stock... Are they simply missing from that list? Seems like there would be some HKS 272s in there... Anyone?
#41
Originally Posted by EvoRecordSetter
well if you say average dyno is about 16% drivetrain loss, that puts the FQ400 at
340HP at the wheels.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Just need AYC,ACD and some coils @ 1/5 the price.
![Frown](https://www.evolutionm.net/forums/images/smilies/frown.gif)
#42
Location: Where you come to vacation and go home on probation! Vegas!
Emre
Emre
#43
I seem to recall the same about the VIII having forged rods and/or pistons. Seems like you could make an FQ-400 without building it up if it is only tuned to ~400 crank HP...
#44
Originally Posted by M3this
Correct me if im wrong but the evo has forged internals ... thats one of the many reasons that the 2.0L can make more power then the USDM STI's 2.5L (sti's dont have forged internals).
I was told the 4G63 was pretty much the "4cyl equivalent" to the Mighty 2JZ(cast Iron Block also).
#45
im sure the FQ400 Cams arent the same as the stock 4g63 Cams, but they arent listed cause they are for that car maybe.
does anyone have more information on the TURBO used? i want some statistics on it, trim and wheel sizes.
