boost and what other two gauges
Hey guys im torn between three gauges right now the defi d series egt oil pressure and air fuel gauge. Im either going to get the oil pressure or air fuel. THe air fuel is about 50 bucks cheaper so which ones should i do thanks alot
so buying an air fuel gauge woudl be a waste of money then?? ( I KNOW THE WIDEBAND IS NOT) ALso buying the egt theres not a need for it? im planning on ordereing these today from SOME Vendor that MIGHT have them in stock if i cant find them then my boost gauge will be up for sale and autometer it is!!!!
A regular AF gauge is useless. You would need an actual wideband o2 that comes with an AF gauge, then weld a bung into your downpipe. You won't need or use an EGT...don't bother.
Get oil temp and oil pressure gauges from Total D Power.
Do they offer the defi products??? Im assuming they do since you reffered me there but they dont have them on their website
Yeah but i already have a defi boost gauge!!!! and i like the way they look but if i cant find them today im going to go pick up some autometer ultra lite here in town tomrrow. Ive always had good luck with autometer anyway.
what are your plans for the car? if you're not tuning yourself or playing with boost much, a wideband is useless too. if you're getting 3 gauges so they fill up the holes in the a-pillar pod you bought then just get whatever is cheapest. if you have plans for your car then get the gauges that coincide with those plans, i.e. if you do track/autox days then a water temp gauge is probably a good idea, etc... asking "what gauges should i get" is as good of a question as "which exhaust is best", there is no real answer
Oh, btw, I hope you aren't really running 25psi daily. You're not even tuned yet, but even with a tune, you can't run 25psi on pump gas.
http://stores.ebay.com/Panda-Racing-...QQftidZ2QQtZkm
