What just happened?
What just happened?
I was playing around in the rain the other night and I came around a 90 degree corner pretty quickly while in gravel mode. The car remained in control but it violently whipped around the corner pretty quickly and I forgot to shift into 2nd. All of a sudden my car just felt like it ran out of breathe or lost power but in a very subtle way. Is this fuel cut or rev limiter? In my old dsm when I hit fuel cut it always felt like my car it a brick wall and when rev limiter would hit it would bounce off the higher rpm very quickly. Not to sure what this was but my rpm's were in the range of 7500-7800.
Well it felt like it lost power. I'm guessing it was fuel cut but wouldn't the rev limiter kick in first? It was pulling hard then all of a sudden you can feel that it just gave up and stopped pulling.
YOu say you forgot to shift to 2nd and that it violently whipped around the corner, but then it gave out of breath or something. Are you saying you made the turn successfully at high speed and then were going straight again when the car suddenly ran out of breath without hitting the rev limiter?
At that rpm it must have been your rev limiter. If you were accelerating it would explain the loss of power you felt. That violent whipping might be the car being thrown off balance.
Yeah pretty much but i was going around the corner almost from a stop in first gear. As I came around the corner I gave it a lot of gas and the back end jerked a bit, I had to do a bit of counter steering and then I came out of the corner in control taking off in a straight line where I immediately should have shifted but didn't and my rpm's were up there but not way up there. They weren't close to 8k but all of a sudden the car just lost power but kept moving, it just didn't pull.
forgot to shift into second... Thats a new one.
