CEL question, O2 fix didn't work.
Well Ive had a CEL on my car since I got it last year as it had a TBE with no O2 fix. Well I just got around to performing the O2 fix and it worked for like 3 days and now my CEL is on again Where is a good place to get codes read for our cars? I think I read somewhere that Autozone could do it but there isnt one close. I haven't had any drivability problems with my car but I want to make sure there isnt another code being thrown.
The O2 fix works, but you need to use the long ones, and you can't just hog it out with a hand held drill! (although some have gotten away with a hand held and a steady hand) A drill press is best as the one that goes on the O2 sensor needs a precision drilled hole, and you DO NOT drill the 2nd one.
i hand held drilled mine just fine. you just have to make sure you dont go with the biggest bit first. gradually widen it. i used two long spark plug foul plugs. just make sure you dont mess up the threads while drilling and you should be ok.
A hand held drill can work... just most people really don't know how to properly use it... and if they do, they either don't have the strength, or a steady enough hand to drill a perfectly straight hole. When you wallow the hole out, too much exhaust gas gets by the undrilled anti-fouler and the over drilled one.
However, if memory serves, I got one CEL right after install. After I cleared it... never had another one... I'm sure I'm coming up on two years without now pretty soon.
That must be what wrong then . I used a drill press and everything but i used the shorter version p# 42002 instead of 42009. ill go get those and try them out please update the how to section put use the long ones instead of short for furture members thanks.
Just buy the eBay o2 sim for 25 bucks. It's easy to install and works fine for me. It seems kinda hit or miss with the spark plug foulers... I decided to do it once and get it over with.
So far I haven't thrown a CEL in about 3000 miles with this setup.
i drilled it out myself with a drill and put it in and i havent gotten a cel for like 10k now. there is no point in paying the 25 bucks for the one on ebay when u can buy the same thing at autozone for 5 dollars and drill it out urself
