Was I hallucinating about 5-point seat belt?
Old Jun 13, 2004 | 06:32 PM
Doug Axelrod's Avatar
tighten the stock seatbelts
Any trick to tighten the stock seatbelts more than they do normally to reduce movement? I take the comments on five point belts without a rollbar, but would like to take the Evo out to the track if only to learn more about its envelope.
Thanks,
Doug
Old Jun 14, 2004 | 05:51 AM
xtnct's Avatar
Schroth makes D.O.T legal 4 point harnesses. They are not 3" wide, but 2" wide like stock. They have anti-submarine technology built in where you don't need to use a crotch belt and you are not required a roll bar. These are great for auto-xing - I use these in my VW. They also make a reel that locks so you can actually move around like a regular belt to reach your radio. The only catch is that you are required to use a proper type of seat (which the EVO has anyway).
More info:
http://www.schroth.com/products_en/privat/privat.htm
http://www.soloracer.com/harnschrothfaq.html
Old Jun 14, 2004 | 08:05 AM
runny_yolk's Avatar
Thanks,
Doug
One trick that you can use is to twist the tongue part of your seat belt around once before you insert it into the buckle. This prevents the lap part of the belt from giving up any slack which will help secure you to the seat. It's not as good as actually strapping into a harness but it's cheap.
tazio
Evo X How Tos / Installations
120
Jun 24, 2022 04:19 AM
barneyb
May 13, 2018 09:24 PM
TxFAkuma
Feb 28, 2017 08:41 AM
evo tracker
Jan 3, 2016 08:18 PM
05 MR
May 18, 2009 10:15 AM
