won't start
won't start
removed battery and left it out for a couple hours and after putting it back in car won't start. it cranks but won't fire. anybody have any ideas? thanks
Originally Posted by CtSilver03Evo
You check all the plug wires, they connected to the coilpacks? Also, connecter still on starter? Do you have any modifications you've made to the electrical system? Check fuses too.
it cranks but does'nt fire. battery was only removed to look at and possibly install in trunk.
Originally Posted by Compjoc
Check the fuses.
checked fuses. nothing is blowen. nothing was done under the hood. only removed battery to look at how much room there is without it.
Reset the battery again. lso make sure the positive cables are well secure, the positive connector on the battery has some big square fuse with electronic component, just make sure that is also plugged.
Carlos
