Innovate gauge where to put it?
Just wondering where people mounted it? It's so thin and I'm not sure how it's going to sit in a 52mm pod. Double sided tape is not something I'll consider. I was going to buy a Defi 52mm and try that maybe. Any help is appreciated. Thanks.
I have the same idea, boost on the right instead. Problem is I have a Defi 60mm boost and I was going to order a Defi pod to slap the innovate in but the pod doesn't have a lip or anything to hold it in and the gauge isn't deep enough to line the pod with double sided foam. This **** is annoying.
Ok. guys, you twisted my arm. And because my budy Turbo OZ asked! What's up OZ?
Here is a pic of my XD-1 installed. I used a stick on clip for cell phones from Walgreens to pair the gauge with the dash. It works great and it is in a good viewing area. I also have the output hooked up to my E0-1 for loging A/F vs Boost vs RPM's.
Love this wideband unit.
What do you think of the spot? I hope the pic helps some of you.
Manie
Manie
