my clutch wanna grap only if ihit after 6k rpm.why?
Old Apr 27, 2006 | 08:33 AM
yesevo's Avatar
my car wanna move eventhough i push the clutch all the way in only after 6k rpm at standstill when i try to launch..
before exactly 6k rpm is fine...
is this normal?
thanks in advance
Old Apr 27, 2006 | 08:51 AM
Carlos4g63's Avatar
Man your clutch is blown out dude, if you got it from a dealer go back to them and have them fix it under a good faith agreement
Old Apr 27, 2006 | 09:37 AM
yesevo's Avatar
no my clutch is act......anyone having same problem?
maybe my engagement point is low?
never adjust clutch pedal adjustment.....how many turns of rotation on the clutch rod needed? i heard 1/2 -1 turn is good ....anyone?
Old Apr 27, 2006 | 09:42 AM
yellowEVO21's Avatar
i'd say it was slipping if it was the stock clutch.
Old Apr 27, 2006 | 09:43 AM
stevEVO8's Avatar
SLipping clutch.
Old Apr 27, 2006 | 10:11 AM
jmartinez1170's Avatar
Just get a new one why even ask.
Old Apr 27, 2006 | 11:56 AM
Warrtalon's Avatar
It's slipping terrbly.
Old Apr 27, 2006 | 02:44 PM
yesevo's Avatar
im not talking about when im cruising...
when i m at standstill. and put it in 1st gear, rev it up to after 6k rpm with clutch all the way in... the car wanna go forward a little...
after i adjust clutch pedal about 2 turns on the rod....its fine..
and shifts like butter even 1-2nd gears at 7k rpm...through all gears.
Old Apr 27, 2006 | 11:14 PM
stevEVO8's Avatar
Ok so I guess you fixed your issue.
Next time give some more info like I just had a clutch installed and its slipping when going into first gear from a stop.
Old Apr 28, 2006 | 06:01 AM
Schuyler's Avatar
Reading the lack of grammar and punctuation ade my head hurt. [/grammar ****]
Old Apr 28, 2006 | 06:49 PM
yesevo's Avatar
i thougth my english was perfect. sorry about my grandma. u can call me a fob.
Old Apr 28, 2006 | 07:18 PM
Turd Squirter's Avatar
+1
I usually don't even read threads where the title could have been written by Frankenstein, but I'm coming close to needing a new clutch myself.
Old Apr 28, 2006 | 07:49 PM
Danny23's Avatar
sounds like your clutch was draging,since you adjusted it and the problem was solved i guess thats what it was.
Old Apr 28, 2006 | 07:52 PM
evo8rcr's Avatar
Originally Posted by Turd Squirter
+1
+2 you a no speak a no english wtf
Old Apr 28, 2006 | 07:57 PM
ThunderOZ's Avatar
Do you have a lot launches on that clutch?
