Need a lil help
Old Apr 29, 2006 | 09:24 AM
MitsuEvoIIX's Avatar
Need a lil help
Im trying to run my car so it boosts off the wastegate and have a capped T in the line so when i want to hook up my mbc i take the cap off and plug it in. How do i do this? i was thinking running the line from the wastegate to the boost solenoid with a T in it for the mbc. Would this work???
Old Apr 29, 2006 | 12:15 PM
moreryce's Avatar
i just took out the solenoid all together...
Old Apr 29, 2006 | 12:21 PM
EvoLutionized8's Avatar
You'll be better off by buying the Forge WGA and setting it desired PSI and then having your ECU flashed for whatever 21-24PSI.... no MBC... I have it set that way now, and I boost at 23PSI to redline with a P2 flash from Works.. Good luck though
Old Apr 29, 2006 | 12:52 PM
bluebyu36's Avatar
i would say stay with the boost controler it's good to have adjustabilty
Old Apr 29, 2006 | 02:21 PM
im installing a 20g-9 and ive heard that it runs min 24-25 psi with the mbc hooked up and turned all the way down. Thats why im going to run off the wastegate.
