Made a mistake buying a pair of jdm headlights
Hi, Well this is the story, my driver side headlight was broken from an accident during a grip run, and since my car inspection date is due this month, I decided to upgrade the look with the JDM MR headlights without expecting to face any issues. So I went along and ordered it since most dealers said it is a plug and play for evo 8-9. Now I found out that people are running into problems installing the jdm headlights into non HID evo's. So far it seems like there is no solutions for installing it beside ordering the HID harness from the dealership which cost big bucks. Is there any other solution to installing it, like aftermarket HID adapter that will convert a 9006 bulbs wiring harness into d2s?
Well....you didn't search before you bought? All I know is HID is a totally different voltage/amperage than normal lights....and they work in a VERY different way than a glowing fillament. I doubt there would be adapters, but then again I have no Evo. For the price, there is a shop that can rewire for you.
hey man, don't worry you're in luck, i installed some oem hid's onto my 06 gsr non-hid, there is a way, but it requires you to cut the wires and rewire the system, the only thing is that if you have no experience with wiring, i'd let someone else do it. IF you want to know how to do it, pm me your email addy, i'll give you a break down.
Just build yourself a wiring harness and get an OEM HID system off www.hidplanet.com and you're set.
terfer
Sep 9, 2011 01:22 PM
Z1 Performance
Aug 11, 2006 04:50 AM
