Comparing Different Dynos..
All:
I can't find any literature on the use of the different dynos (dynapak, dynojet, and dyno dynamics). I'm trying to compare if you get a dynojet reading, what would it be on a dynapak?
Thanks,
-M
Thanks,
-M
There's no use in trying to compare, because there is no direct comparison between dynos. Hell, even Dynojets don't all read the same, so you can really only go by trap speeds. Some people say Dynapacks read lower than Dynojets, but I've seen a guy put down 10 more whp on a local Dynapack than on a local Dynojet with the same setup within a few weeks. Things like correction factor also skew things.
Get your trap speed, then you know approximately what you make on a Dynojet (uncorrected).
-M
You should also know the weight of the car. I get on the scales to see my race weight each time I go to the drag strip (if that track is equipped with one).
-M
David Buschur
29
Jan 26, 2006 07:49 PM
