Floor Jack Recommendation?
Old May 25, 2006, 12:05 PM
spencer26's Avatar
A couple of months ago I bought the Torin Aluminum low height 1 1/2 ton floor jack with 3-ton jack stands at Pep Boys for $149.
I think they were running a special at the time
So far it has been working out good
Old May 25, 2006, 12:48 PM
IXmr321's Avatar
i found one at wal-mart not to long ago. its a 2 ton floor jack made from aluminum so its super light and its small enough to get under the car without having to drive onto a piece of wood first its was only $80
Old May 25, 2006, 12:56 PM
Dr. SS's Avatar
i have a 4,000lb SUV jack, that has extra high lift range, it takes less than one pump to get it to the lift point and then just a few more to get the car high enough for any jackstand....
super quick to use....
Old May 25, 2006, 02:34 PM
sonicnofadz's Avatar
You do not have to have a low clearance floor jack to fit under an evo (I should know, my car is lowered 2-2.5 inches). You can fit a fairly tall jack just behind the front wheel wells and under the rear differential (with a wooden 2x4" block used as a pad) just fine.
Old May 25, 2006, 04:29 PM
kySTi's Avatar
Originally Posted by naucrx
x3!!!
This is an awesome jack!! 3000lb capacity which is plenty for the EVO and only $119.
x10
Dallas J
74
May 31, 2019 10:58 PM
dagle
Jul 12, 2016 12:29 AM
EVOFans
Apr 27, 2016 08:47 AM
Red08EVO
Jan 2, 2009 09:16 PM
Bueller
Oct 29, 2008 02:50 PM
Quick Reply: Floor Jack Recommendation?
