I am stuck on which direction to take with my Evo…
The stock turbo can't get close to maxxing out the stock engine. It can push maybe 29-30psi peak, but it won't sustain more than 22psi or so by redline. This is all basic information easily found all over this site.
and in terms of the stock turbo you can try and push whatever you want, but i believe that the efficiency drops way off after 25 psi or so...this would cause your turbo to really heat up and you will start to have turbo related problems. If you can find a compressor map for the stock turbo you can see exactly how much boost you can run. I looked at one a while back but cant remember where I found it.
Originally Posted by ~EVILEVO~
So what kind of numbers are necessary to run a 11.0 @1_ _ in my IX?
Originally Posted by 12mnkys
i was running at 400 wheel horsepower with stock internals before the ring land broke and trashed the motor....
af's were sweet...11.5...i am thinking that there was a weak spot on the #4 piston...egts never got any higher than 800c...when i pulled the head off you could see that the 3 good cylinders were perfect, no signs of any detonation anywhere...i have some pics i may try to upload them.
Originally Posted by 4G63V0
LMAO- The guy was asking for opinions- and last I checked this was a public forum so I gave him my opinion.
I don't come to the shop, and wouldn't anyways- too far. I'd MUCH rather drive an extra 1K miles to have a real shop like Vishnu, AMS, Buschur, or TurboTrix work on my car. They all have proven track records, slips, vids, charts, not to mention an awesome customer following.
Last I heard Myne's was blowing up a bunch of engines.
