is this boost safe?
is this boost safe?
im spiking at about 23.5 psi and holding about 21.5 psi i just want to make sure that is safe before i drive at that boost level for too long.
heres my mods
hks bov
walbro fuel pump
reflashed ecu
turbo back exhaust
K&N drop in filter
forge MBC
ACT clutch
Lightened flywheel
thanks
-nick
heres my mods
hks bov
walbro fuel pump
reflashed ecu
turbo back exhaust
K&N drop in filter
forge MBC
ACT clutch
Lightened flywheel
thanks
-nick
heres my mods
hks bov
walbro fuel pump
reflashed ecu
turbo back exhaust
K&N drop in filter
forge MBC
ACT clutch
Lightened flywheel
thanks
-nick
heres my mods
hks bov
walbro fuel pump
reflashed ecu
turbo back exhaust
K&N drop in filter
forge MBC
ACT clutch
Lightened flywheel
thanks
-nick
Originally Posted by nj1266
How are you reading your boost? If you are using a gauge, then more than likely your gauge is about 1-2 psi off. Assuming 1.5 psi off, then you are spiking to about 22 psi and holding at 20 psi. Where is the boost gauge by redline?
