Dry Rotting Tires
Dry Rotting Tires
Hi everyone I was wondering if anyone knows about dry rotting tire? How long does it take to occur and under what circumstances? I am going to have one of my vehichles sitting for 12 months and only putting about 500 miles on the car during that time period.
I had dry rot on some Toyo Proxes, but that was in Vegas. I don't know if it will be a problem in Philly. FWIW, I had my Camry sitting idle for almost a year since I bought my Evo, and the Firestone tires did not dry rot at all. THat's with a full sumer under the California sun.
Put the car up on jackstands and take the wheels off....that will eliminate dryrot and/or flatspotting.
But, you cannot leave the suspension hang, so place your jack stands on a load bearing part of your suspension. That way, the suspension is compressed like the car is parked, and your tires are safe from the enviornment.
my $0.02
-Vince
my $0.02
-Vince
Here's some technique on long term storage. Thoroughly clean your car, inside, outside, underneath, and so on. This will get rid of the corrosive materials you pick up just driving around. Put a good coat of wax on your car, and high quality car cover over it. Put the car on stands and remove the wheels. Thoroughly wash the wheels and tires. Do not put anything (Armor all and so on) on the rubber. Get four large trash bags, and put your wheels/tires inside the bag. Get as much of the air out of the bag and zip tie them shut. Store your wheels/tires on its side (not standing up), in a dark room where the temperature is constant throughout the year.
In addition, change your oil and filter, have as little gas in the tank as possible, and disconnect your battery.
If you have access to Nitrogen, fill your tires 100% with it. It’ll keep the temperature in the tire more constant, and it doesn’t have all the crap that’s in air.
Bringing the car out of storage.
Change the Oil and filter, spark plugs, charge the battery (you may need a new one), put fresh gas in it, bleed the brakes (since the car is still on stands), and then put the wheels/tires back on. Go for a short drive, to make sure everything is ok, then go for a longer drive (30+ minutes plus).
