Question for people running high boost
Old May 31, 2006 | 07:22 PM
smoothmarine187's Avatar
Veteran: Marine Corp
For those of you that are running high boost.........how many psi. are you hitting in every gear, from 1st to 5th?
Old May 31, 2006 | 07:28 PM
Evojun8's Avatar
I am running 24 PSI no taper on a Apex AVCR with 65 % duty, but i have a Walbro pump. runs good no fuel cut.
Old May 31, 2006 | 07:30 PM
supersupra's Avatar
You have the stock turbo?
Old May 31, 2006 | 07:33 PM
Evojun8's Avatar
Yes sir i do, what i do i need is a SaFc 2, its running kinda rich, gas mileage sucks.
Old May 31, 2006 | 07:42 PM
Warrtalon's Avatar
You're only running rich at WOT, which has very little to do with your gas mileage. Having all those mods with no tune is senseless, and I highly doubt you run 24psi with no taper in every gear despite what you may think. Also, running 24psi on pump gas is very poor judgement. The fuel pump doesn't allow you to run more boost when on pump gas.
Andrew, I've never used a MAP sensor to log my boost in every gear, and it comes on way too fast in 1st and 2nd to get a good idea. I 24-25psi in 3rd, then it gradually increases in each gear up to 6th with a spike of around 28psi.
Old May 31, 2006 | 08:39 PM
alright thanks for the info!
