Ideal Differential SetUp?
quick question..
is it possible to blow out the AWD in an evo ? and if so how could you tell if its gone or on its way out ?
my car wont do AWD donuts like it used to. i already need to buy new tires.
my friends think because the tires are very worn down that they are much more sticky so its harder to get the *** end out.
Re: quick question..
There is the possiblity that the tires are now slicks and have more contact patch then the tire with tread, but the rubber at that point should be less sticky than the rubber was was with tread, would probably near the same overall traction level
Re: Re: quick question..
Originally posted by chronohunter
It is possible to overheat and cook the center viscous diff. I have done it on a 993tt that had a bunch of hp. Donuts in the dry could put enough strain on the center diff to do that, you could have also worn out the clutch pack in the rear LSD. Too many donuts in a row? I won't comment on the wisdom of such driving but I'm sure someone else will...
dealership should fix it for me i hope.
Re: Re: Re: quick question..
There should be fluid or oil in the center viscous differcials right?? what is the maintainece schedule on that?!?! change oil 30k etc?!?! or you don't have to change at all... I think all I need is a front lsd to replace the open lsd, I am ok... not too much off road racing for me to change to a torsen type...
is this something that is costly to fix ?
Re: Re: Re: Re: quick question..
ACD is a mechanical center diff (similar to the one in the rear) that is controlled by a computer that can change the locking of the diff it measures things like speed steering angle throttle position brake on or off etc. that way the diffs locking characteristics can be adjusted on the fly (by the computer) to minimize understeer and maximize traction. It also has 3 driver selectable modes Tarmac, Gravel and snow that adjust the diff for these different traction conditions.
A viscous diff works like a torque converter on an automatic. A viscous fluid allows only a certain amount of "shear" before it thickens therefore it prevents the shear plates from rotating at vastly different speeds (this provides the locking). It always locks the same way unlike the ACD which is active and therefore more adaptable.
There is more to it than this but those are the basic differences. You can also do a search, as we has discussed this several times before. Hope it helps
I would add, that main ACD's advantage is it's proactive nature in opposition to reactive nature of non active. DCCD-A is the best example where computer controls the torque split to stabilize the car, not just responds to slippage.
Lightsaber
Evo X How Tos / Installations
Jun 5, 2017 12:35 PM
GTWORX.com
Evo 'For Sale' Suspension / Brakes / Handling
68
Jun 6, 2009 09:08 PM
2003, acd, center, cusco, diff, differential, drift, evo, evolutionm, front, quaife, setup, snow, trailbrake
