possibel remedy for slight 2nd gear grind.
Old Jun 5, 2006 | 11:00 AM
19psi's Avatar
possible remedy for slight 2nd gear grind.
This is for those who have slight 2nd gear grind or crunchy 2nd gear.
I have slightly over 1000k on my 06 and had slight grind or crunchy 2nd gear shifts.
I've adjusted the clutch (there is a how to do on the forum) and it shifts like butter now.
Slight grind is completely gone now.
This is a very easy adjustment and is highly recommended to those who are expreiencing slight grind.
I believe if you keep driving the car with a slight grind for a extended period of time, this will eventually cause damage to your synchros.
Just make sure you turn the clutch rod no more than half a turn at a time and test drive it to get a perfect setting.
Old Jun 5, 2006 | 11:02 AM
TimDC2x's Avatar
What tranny fluid are you using?
Hell of a lot of miles on that IX you got
Old Jun 5, 2006 | 11:05 AM
CGs's Avatar
CGs
Yep, did the same thing on my '03 -- worked like a charm.
What impresses me is 1000k miles .. as in 1,000,000 miles .. j/k
Old Jun 5, 2006 | 11:08 AM
19psi's Avatar
Iam still on stock tranny fluid.
I havent changed anything on the car yet.
I am scheduled to go in for first oil change/tranny fluid next monday.
I really hope this remedy helps some of you guys.
Old Jun 5, 2006 | 11:14 AM
.MM's Avatar
.MM
thanks!
do you have a link to the "how to" page to do this?
Old Jun 5, 2006 | 11:29 AM
19psi's Avatar
you can also find it @ evomoto.com
They have tips with pictures on how to do it.
Old Jun 5, 2006 | 12:24 PM
300evoIV's Avatar
can some one send me a link on how to adjusted the clutch please. i need to adjust it asap
Old Jun 5, 2006 | 12:37 PM
19psi's Avatar
go to www.evomoto.com and look on top of the page for install tips.
There should be a lot of info on how to's on that page.
Another wesite is www.lancershop.com
It's really not that hard to do.
All it takes is maybe 10 minutes tops.
You just need a 12mm open rench.
Old Jun 5, 2006 | 01:17 PM
300evoIV's Avatar
link does not work
Old Jun 5, 2006 | 01:25 PM
19psi's Avatar
try www.lancershop.com
I just tried it and it worked.
Old Jun 5, 2006 | 01:52 PM
byron3636's Avatar
did you adjust it higher or lower... i'm thinking lower.
Old Jun 5, 2006 | 02:11 PM
19psi's Avatar
higher.
When you are adjusting you want to turn it clockwise.
This is when you are looking down towards the firewall.
When you are looking up towards the steering colum from the floor of the car, you want to turn it counter-clockwise.
I am not saying this will cure all the problems with shift grinding but it will cure most of it.
I did it to my car last week and it has cured all the grinding/crunchy feel of 2nd gear.
Old Jun 5, 2006 | 03:10 PM
BrianGT's Avatar
damn, 1000k miles!!! wtf?
Brian
Old Jun 5, 2006 | 04:36 PM
19psi's Avatar
LOL.
What's wrong?
Old Jun 5, 2006 | 04:38 PM
llxzxll's Avatar
you COULD just learn how to shift smoother/drive normally.
Quick Reply: possibel remedy for slight 2nd gear grind.
