Cooling down with the heater on?!?
When i was at the strip, these two guys with an Srt4 and a Cobalt SS told me to turn my heater on all the way (to 4) and to turn the dial to defogger... they told me something about how this would act as an second radiator and help cool down the engine, till i waited for my run.. is this true? any ideas?
...just to add something while i posted, i removed the condoms of the bulbs to get the guage lights brighter, putem back on (which dont seem too brighter tho) and i feels like my speedometer is lower than it should be when im driving around... maybe its psychological, (the needle stays at zero for the first second i throttle it, then rises -never watched if it did so before)...clues?
It is physically true that turning on the heater is like having a second minature radiator.
Not sure how big of a difference it will make....
dude its cuz the heater core is how it makes heat which is a tiny radiator. to me the guys are retarded. and since the engine is off the interior heater is only gonna cool off whats in the heater core. just leave ur car off or run a switch to ur fan and turn it on but to me its not worth the hassle.
yea when my mr2 turbo had overheating issues and i was forced to drive the car to different shops, i always turn on the heater when the needle in the engine temp. gauge in the dashboard is goin up, and this always cools the engine temperature down.
Originally Posted by MuslimEvoFreak
I don't know how much of a difference it makes but I know that when my moms car was overheating I turned up the heater all the way to get the hot air out and reduce the temperatures.
it cools down alittle due to when you have the heater on it circulates the coolent throught the radiotor wich cools it down a little. i tried it but didnt really make a difference. just kick back for a couple of minutes and youd be straight
on my 3000gt, i actually data logged it, the coolant temp went down about 3 degrees C under. Ever since i seen that happen, on my evo, i've always had my car on "heat" most of times, unless the weather gets un-bearing. I should try logging the evo to see the difference.
thats cool to know.. anyone have a clue on my speedometer stuff? i dont want the rpm to be 8k and show me 7k... i disconnected the white plug with the wires, when installing, the wires seemed ok, could it be pyschological? i mean, when your exiting a parking lot (at those speeds) does your needle stay at 0 till you start hitting the throttle properly?
+1
its like a 2nd radiator the heater core is a small radiator you actually don't turn on the fan just turn the knob to hot and it opens the valve to the heater core.
the thing about turning it to defogger might be off though, I think the defogger uses the a/c core to dry the air, so like to put the least strain on the engine youd want it on any setting other than defogger.
