catback experience!
catback experience!
i was installing my catback system today, jacked the car up properly and turned out damn near all of the bolts from the cat and back are rusted the **** out of where WD40 doesnt do a thing and no matter what i could not even loosen one of the 20 bolts under the car at full strength. any suggestions or should i jsut go to a shop and have them use airtools?
if you take your ratchet and put it on the nut and take a hammer and hit it a few times it will break free. also soak it with penetrating oil...something other then wd-40... they sell it at autozone or pep boys... works great. i had the same problem.
That happened to me aswell, so what i did was take out the whole exhaust including the downpipe and then loosen when it was out from under the car, more leverage when standing up then laying on you back.
you could try putting a length of pipe on the end of your wrench/ratchet for more leverage. something that will slip over the tool and extend it....if you have the room under the car that is...along with some better penetrating oil.
LOL that sounded a little diffrent in my head!
I would also suggest an impact wrench it will save you the heartache .... i tried to do it with a breaker bar but was really scared that I was going to break my downpipe from all the stress that I was putting onto it when trying to break torque.... if you cant get to an impact wrench then spray a lot of penetrating oil onto it and leave it to sit over night then try the breaker bar and a quick swing with the hammer idea.... that's what we do all the time when working on helicopters....good luck
