Got cams and dyno done this weekend!
Old Jun 19, 2006 | 11:23 AM
AC556k's Avatar
First a big thanks to Scott at TTP engineering! He put in my cams and worked an extra 3 hours at the dyno tuning my car before his family vacation . Also a big thanks to Central Florida Turbo and their Mustang Dynamometer machine! But even with a boost leak (at the turbo outlet, one of the silicon sleeves pulled loose) I did 306hp & 320tq. I notice everyone lists their mods so maybe it will be indicative of my hp numbers.
downpipe
MBC
Hard IC pipes
Greddy catback
UR test pipe
GSC 264,272 cams
Walbro fuel pump 255
Excellent tuning
Old Jun 19, 2006 | 11:32 AM
Ph3n1x's Avatar
How much boost>?
Old Jun 19, 2006 | 11:44 AM
Warrtalon's Avatar
A lot if his tq is that much higher than his HP, unless that leak was causing a power loss up top.
Old Jun 19, 2006 | 11:48 AM
TTP Engineering's Avatar
22psi peak.
anjapower's Avatar
if that's on a dynojet, those numbers are pretty weak.
I don't know if the leak is causing the numbers to be so low but you're about 40whp down from where you should be.
Old Jun 19, 2006 | 11:50 AM
AutobonEvo's Avatar
^ i think it was a mustang dyno.
Old Jun 19, 2006 | 11:52 AM
Warrtalon's Avatar
Yeah, Mustang Dyno, but it's questionable if this one reads like a Dynojet or like Buschur's MD. In the past, it has read like a Dynojet, since JoeyMia put down 357 on pump gas with the stock turbo on this same dyno. You never can tell with these MDs.
anjapower's Avatar
whoops missed that...but isn't CFT's dyno recalibrated to read like a Dynojet?
Old Jun 19, 2006 | 11:55 AM
No, their hard drive crashed and Mustang updated their computer and firmware. Reads lower for the past few months.
Old Jun 19, 2006 | 07:04 PM
evolancer04's Avatar
In his first post it says mustang dynometer!!
It would be interesting to see what #'s you pull with that boost leak fixed. 306 whp on a dynojet reads out to about 350-360 i think. Dont quote me on that one.
Also AC556k what did you use to tune with. UTEC, ECUTEK, hydra???
Old Jun 20, 2006 | 08:45 AM
AC556k's Avatar
I am not sure since I have no idea on how to "tune", but I remember seeing Zeitronix on some of the tuning equipment.
